There are 2 more buttons on xp10 that are not attainable with VDJ. They are north-left of jog-wheel. Why VDJ doesn't use them???? You could adjust 2 more functions on xp10! In my case i would adjust cue 1 and cue 2 on them.
Dj Nikki
Dj Nikki
geposted Wed 17 Aug 05 @ 12:16 pm
I think cue 1, cue 2 and cue 3 are allready affected to the buttons "in", "out" and "reloop" in the standard VDJ settings for the XP10...
But of course you can affect them to whatever you want...
geposted Wed 17 Aug 05 @ 1:21 pm
sure, i gave just an example for my setup. but those 2 buttons would be useful if i was able to use them.
Dj Nikki
Dj Nikki
geposted Wed 17 Aug 05 @ 1:23 pm
In fact, they are used: they are the shift1 and shift2 buttons (correctly labeled for VDJ on the VDJ XP10 units, not on the original XP10 units).
With those, you can program two additional actions for each of the other buttons (under the shift1 and shift2 tabs in VDJ's xp10 config panel).
For example, I have programmed:
CUE1 = goto cue 1
SHIFT1 + CUE1 = set cue 1 at current position
SHIFT2 + CUE1 = delete cue 1
look at the VDJ XP10 button labeling to have a good idea of how VDJ implements xp10 buttons.
Nicolas
CUE1 = goto cue 1
Nicolas
geposted Wed 17 Aug 05 @ 4:05 pm
Thank you very much!
God, i like this forum =)))
Dj Nikki
Dj Nikki
geposted Wed 17 Aug 05 @ 4:31 pm
