What ram and MHZ do you need to use tvc is my pc strong enough if he can play with the hercules
geposted Mon 22 Aug 05 @ 1:23 pm
Minimum I would reccomend: 1.5ghz + proccesser
512mb RAM
For best performance: 2ghz + proccesser
1024mb RAM
Alot of users only have 512mb and have no problems with the timecode, i've only heard reports of software slowdown after 4-5 hours in some cases, but some use this amount trouble free, ideally you would have more for better stability (only NEEDED if you will gig with VDJ & timecodes).
512mb RAM
1024mb RAM
geposted Mon 22 Aug 05 @ 2:55 pm
The greater the better... For good time responses, go for the max you can pay. My only observation is the RAM: 1GB RAM is better, but min 512MB.
geposted Mon 22 Aug 05 @ 9:19 pm
