Forum: VirtualDJ Skins
Topic: invalid skin file?
when i try to change my skin it says invalid skin file (error line 0 in xml)...so thats what is says so how do i fix it and im fairly new to it so please dont get to technical
geposted Thu 08 Sep 05 @ 3:45 am
djjbPRO InfinityMember since 2004
open the xml with internet explorer.
maybe than you'll see what's wrong.
geposted Thu 08 Sep 05 @ 6:15 am
What version of Virtual DJ do you have ?
geposted Thu 08 Sep 05 @ 6:57 am
vin3245Home userMember since 2005
sorry i had to make upa new name my pw wasnt working, anyways im using version 2.04 and i dont know how to change anything in the xml, it dont let me write in xml i can only view what it says and it says somethign wrong with the style:heres exactly what the xml says in teh dennon and i wanna use this one, kinda says same thing on top for all the xml i wanna use, so what do i do?
This XML file does not appear to have any style information associated with it. The document tree is shown below.
- (c)2003 - Kal�o - FRANCE
CHANNEL 1
\n
CHANNEL 2
\n
MENU
geposted Fri 09 Sep 05 @ 3:00 pm
sorry i had to make upa new name my pw wasnt working, anyways im using version 2.04.
contact e-service or by this program
geposted Sat 10 Sep 05 @ 6:21 am
Check to see if the bmp is listed first in your zip file. That would cause the error you mention.
The xml has to be listed first in the zip file.
Greg
geposted Sun 13 Aug 06 @ 8:15 am
JeremKPRO InfinityModeratorMember since 2004
No need to answer in a topic that is one year old.
geposted Sun 13 Aug 06 @ 5:46 pm
Sorry, my bad. Didn't check the date.
Greg
geposted Mon 14 Aug 06 @ 1:13 am
