Hi, just wanted to know why atomixmp3 doesnt play files with lower than 192Kbps? I've got a couple of files with 44kbps, but they dont seem to be able to play at all.
Thanx for all the feedback.
geposted Fri 09 Sep 05 @ 4:36 am
Not playing 44kBps may be intentional my friend... why would you even want to play audio at such low fidelity... is it a talking head / voice only or something like that ???
geposted Fri 09 Sep 05 @ 4:51 am
I just probe AtomixMP3 2.3 with a 96KHz song and play it just fine. I find a 56Kbps song (from southpark Kyle Mom is a B*tch) and play it fine too. Maybe your mp3 have some kind of error.
Maybe the 44kbps are 44KHz for sample rate (which is totally different stuff)...
You could play any MP3 and WAV. I think your problem is other...
geposted Fri 09 Sep 05 @ 5:02 am
The files are proper mp3 files, that is, they play fine when I play them on the Windows Media player. Is there a patch or something which I have to download to play files lower than 192kbps??
Also, is there a way to convert the file Bit Rate? Say, change it from 44kbps to 192kbps???
geposted Sat 10 Sep 05 @ 12:42 am
Try this:
http://www.virtualdj.com/swreg/purchase.html
Good Luck!
Good Luck!
geposted Sat 10 Sep 05 @ 6:01 am
