Before i go buy the Audigy 4 soundcard, can someone please verify for me that it can do 2 x LINE-IN and 2 x LINE-OUT.
Here is the product description.
http://www.creative.com/products/product.asp?category=1&subcategory=434&product=14103&nav=1
Thankyou
Thankyou
geposted Sun 27 Nov 05 @ 12:15 am
lokalp,
No, Audigy 4 not have 2 line inputs in the rear panel. It has one inside (AUX IN) for the CD-Player and 1 outside (LINE IN).
This soundcard is better and has 3 Line Inputsm 2 in the front and 1 in the back: (Creative X-Fi Platinum)
http://www.creative.com/products/product.asp?category=1&subcategory=208&product=14065
geposted Tue 29 Nov 05 @ 12:30 am
Take my advice and avoid any soundblaster card, (@acw, one day i'll take the time to write the top 10 reasons why...)
Look for something from M-Audio, like the delta44.
geposted Tue 29 Nov 05 @ 2:20 pm
I have the Timecoded Vinyl and TT's but right now I have my labtops original sound card and an external Creative Sound blaster 24BIT. If I was to get the Delta 44, would that be all I need? Or would I still need another soundcard. Cuz I'm having a hell of a time trying to get the timecoded vinyls to work with the sound cards I have. What do you think?
geposted Tue 29 Nov 05 @ 3:36 pm
Don't forget that your using a laptop jzafra.
The Delta 44 or 66 is a PCI interface and is installed in a desktop PC.
geposted Tue 29 Nov 05 @ 3:51 pm
Ohh, so then what would you suggest I get, cuz right now the Maya44 is like impossible to get. And I want something good.
geposted Tue 29 Nov 05 @ 6:50 pm
@jzafra
You can find some maya's here:
http://www.thomann.de/thoiw2_audiotrak_maya_44_usb_prodinfo.html
Other options for Tcv and laptop here:
http://www.virtualdj.com/forums/41771/Hardware_Technical_Support/List_of_external_Audio_Cards_for_Timecode_use__comments_.html
geposted Wed 30 Nov 05 @ 1:56 am
Thanks man, that's awesome. The truth is I really just want to go with what works, and from all the forum reading I've done, MAYA44 is absolutely the best tool to use to do what I want just like everyone else is trying to do. So thanks for the link I've ordered mine right away. No more searching. Thanks once again.
geposted Wed 30 Nov 05 @ 5:32 pm
you're welcome -)
geposted Wed 30 Nov 05 @ 6:16 pm
I am using.
p4 2.4, 1g ram, Creative Audigy, 2 turntables with timecoded vinyl
Ok well I have an Audigy card amd o used the KX Drivers so i mapped the inputs to the 2 front jacks (Aux In 2 and Line In 2 / Mic In 2 Jack) and the outputs on the back of the computer. I have the save file for the settings if anyone wants it. kxaudio drivers made my Audigy Card in a Dj Sound Card. There is one issue it always says -8.0 -8.1 -8.2 even when slider on vdj and my turntables are both at 0, It affects the bpm reading as well so now the bpm displayed is not the corect bpm. Did this happen to anyone else ? And has anyone experienced something like this with other hardware ?
geposted Thu 26 Jan 06 @ 10:05 am
Thanx, now I can sorta rest a little better hahaha :)
geposted Sat 28 Jan 06 @ 11:13 am
