Is it possible for me to listen to (for example) turntable 'A' in my headphones while turntable 'B' is playing through seperate speakers? I need your help because it is limiting what i can do with the software. I have a 3GHz P4 Laptop with 1 Soundcard and DJ Mixstation 2 (Full Version).
Thanks in advance, Matt
geposted Tue 29 Nov 05 @ 12:00 am
You can use the headphones but you may need to sound cards or one 4.1 or better soundcard. I think that is your llimitation.
geposted Wed 30 Nov 05 @ 2:00 am
You can't do that with dj mix station 2. You need at least dj mix station 3 for that (but there is virtualdj - home edition 2006 now ;-) )
geposted Wed 30 Nov 05 @ 2:05 am
I have the same problem, i have a 5.1 sound card. I have Virtual DJ 2.0. How do i preview one song on my headphones and listen the current song on my speakers?
geposted Thu 01 Dec 05 @ 11:48 pm
errtu, You are not allowed to do that with the version you have. You need the full version.
geposted Thu 01 Dec 05 @ 11:58 pm
im planing to buy the new version, if I had it, what do I need to do?
Moderated by ACW. I delete your repeated posts.
geposted Fri 02 Dec 05 @ 12:00 am
Use audio preferences to select the correct setup.
geposted Fri 02 Dec 05 @ 12:36 am
