Topic: Music skip sometimes with Verison 3.2
dri66PRO InfinityMember since 2005
Hello,
I use VIRTUAL DJ since the version 3.0 and I wass realy hapy with all the functions , I have never notice any fault or problem.
This week I have installed 3.2 and since this version ,sometime the music skip for less than a second , I do not know yet if the music skip forward or backwards , but it is not in the beat :(
I will try do but back the old version 3.1 to hear if this still play OK.
If one of you has the same problem and you have some hint , please let me know ;)
Best Regards,
Didier.
geposted Sun 11 Dec 05 @ 5:43 pm
It all depends on your computer specs. Are you mixing videos as well?
Try going into the config tab and look for the general settings and change your reactivity setting to low.
V3.2 uses a lot more resourses than the previous versions for now until the next release.
Give it a try and see.
MS
geposted Sun 11 Dec 05 @ 5:49 pm
ThaManHome userMember since 2005
Out Auto Beat on OFF and it shall not skip anymore !
geposted Sun 11 Dec 05 @ 11:23 pm
Thank you for the feedback , since I have done the above recomandation , it work fine again ;)
The computer I use is a IBM T40 1500Mhz 768MB of RAM.
I do not use Video Clips.
Thanks again for your help.
Best Regards,
Didier.
geposted Mon 12 Dec 05 @ 2:36 pm
