Do you have the same problem? I found a bug in VDJ 3.2. If you select jpegs or gif files for the video slide show VDJ loads every pic into the RAM and the swap-file. After a while the prog crashes. If you use bitmaps vdj unloads the pics after showing it without a crash.
Daniel
Daniel
geposted Mon 12 Dec 05 @ 12:12 pm
Weird? convert them to bmp then :)
lots of progs that batch convert pics.
geposted Mon 12 Dec 05 @ 6:37 pm
Of course, i did it. but I was confused before I found the bug.
geposted Mon 12 Dec 05 @ 11:32 pm
I have had the same...with the slide show too...
geposted Tue 13 Dec 05 @ 12:32 am
this is so common, first as a designer, bmp is huge in size compared to gif or jpeg. I refuse to email and add pics and change them. 99% of the pictures i have as slides are jpegs. this issue needs to be resolved. also i wasnt happy with the text not having a way to change the font. I have 20000 store bought fonts i would love to load. the video also needs a custom logo ability. I believe if im going to do some thing incredible im not going to do it half assed!!!!! thanks for starting this forum,
www.tycoonentertainment.com
mike
mike
geposted Mon 15 May 06 @ 10:19 am
1) This bug has been corrected: http://www.virtualdj.com/products/virtualdj/history.html
2) This topic is 6 months old. Are you going to say something on other old topics?
3) You use DJ mix station 3, so this old bug doesn't affect your version of VDJ.
geposted Mon 15 May 06 @ 11:00 am
