i cant burn these type of files how do u make them n2 mp3's i know there has to be a way or else this recording process will be worthless
geposted Tue 13 Dec 05 @ 7:46 am
GLOCKBANKS,
You can burn in mp3 and do other things with the purchased version of VirtualDJ. The Demo or other versions don't work 100%.
Good Luck!
Good Luck!
geposted Tue 13 Dec 05 @ 7:51 am
i got the full version theres 1 part where it says record to diff files mp3 but i click on it & it wont record it only records to cue/bin files
geposted Tue 13 Dec 05 @ 3:30 pm
If you have purchased the full version, it is a good idea to enter necessary info so it will show you as a full version owner.
geposted Tue 13 Dec 05 @ 8:09 pm
You have to put your serial number into your profile to be here as a full user. That's why I write before, you need the purchased version of VDJ. http://www.virtualdj.com/fusers/modifuser.html
All I know is tht the full purchased version of VDJ works. The Demo don't do this. So my conclusion is your current version is wrong.
Good Luck!
geposted Tue 13 Dec 05 @ 9:15 pm
