Ok...now that I've decided to buy a Maya44 USB soundcard so I can start incorporating Time Coded Vinyl in my setup the soundcard is very difficult to locate now.
Any help on where I can locate one of these elusive cards here in the US? Or if the Maya44 USB is completely off the market, what are the best alternatives?
Thanks again!
Cool Cliff Rock
Thanks again!
Cool Cliff Rock
geposted Wed 14 Dec 05 @ 5:23 am
Hoth2001,
One of the problems is that you need VirtualDJ to use the TCVs. You have to upgrade then.
As a user of atomixmp3 you can have a discount price on VDJ here
The Maya 44 USB is out off stock from almost every store. Anyway Musicians Friend tells the will have it yesterday...
http://www.musiciansfriend.com/srs7/g=home/search/detail/base_pid/700355/
I doubt, but you could give a try. Other working Soundcards are recommended here:
http://www.virtualdj.com/forums/41771/Hardware_Technical_Support/List_of_external_Audio_Cards_for_Timecode_use__comments_.html
geposted Wed 14 Dec 05 @ 7:02 am
I orded mine on the 15th and got it today from musiciansfriend.com.. Loving it...
Clasik
Clasik
geposted Thu 22 Dec 05 @ 6:49 am
i think you'll find that this is maya 44s twin and at half the price and also in stock. http://www.microdirect.co.uk/ProductInfo.aspx?ProductID=8853&GroupID=1140
geposted Fri 23 Dec 05 @ 6:39 pm
correct me if im wrong though because i think it just has 1 input not sure so some1 back me up.
geposted Fri 23 Dec 05 @ 6:47 pm
Maya 44 USB has 2 Stereo Line Inputs (4 RCA IN) and 2 Stereo Line OutPuts (4 RCA OUT), the terratec model you are pointing isn't the same as Maya 44 USB is more like a 5.1 USB soundcard only with 1 Stereo Line Input only.
geposted Fri 30 Dec 05 @ 4:05 am
