Is there a way to change the Font size for the explorer and playlist in Virtual Dj 3.2?
I find myself staring into the monitor to try and read titles to find what I'm going to be playing next which isn't good.
I also use Traktor Dj Studio 2.6 and this has an option to change the font size.
geposted Tue 20 Dec 05 @ 4:14 pm
I think this is a skin issue, look at the skins forum.
geposted Tue 20 Dec 05 @ 11:28 pm
Cheers, I had a look and found this post. Managed to figure it out.
http://www.virtualdj.com/forums/43678/Skins/Low_Visibility_Skins.html
Just open
C:\\Program Files\\VirtualDJ\\Skins\\Default.zip
edit 1024x768.xml in NOTEPAD (if that's the one you are using), and change the BROWSER section font sizes.
Easy when you know how isn't it. Just seems a lot of messing about.
Just open
geposted Tue 20 Dec 05 @ 11:44 pm
