Topic: Help! How do I monitor next song?
SpymixHome userMember since 2005
Can anybody please tell me how do I listen/monitor the next song? Do I need additional software/hardware? Where are the instructions for this? Why is this company not honest about this deficiency? I bought the professional version and have asked DJs (I'm not a pro, just want it for home use), but nobody seems to know what I would need. Thanks
geposted Wed 28 Dec 05 @ 3:01 pm
geposted Wed 28 Dec 05 @ 4:28 pm
Hi. Thanks for replying. I already modified my profile and added my serial number. So how do I do monitor the next song?
geposted Wed 28 Dec 05 @ 5:00 pm
Please tell me if I need to get additional software/hardware?
geposted Thu 29 Dec 05 @ 6:15 pm
depending on your hardware there are several ways, each supported by its own soundcard configuration inside Atomixmp3 software.
For prelisten you need 2x signal out, one for master, and one for headset.
This can be done in several ways:
- 2 soundcards
- one 4.1/5.1 soundcard
- stereo splitter if only one soundcard with one line out (gives you mono in master and headphone)
Depending on what you have, choose the correct soundcard setup inside your software.
Look at the images in soundcard setup, they explain a lot :)
hope that helps
geposted Thu 29 Dec 05 @ 6:25 pm
