Right, i no this has probably been asked before but can someone please just tell me how to broadcast. It looks really easy. So i click start recording and it goes broadcast server running, you can listen by connecting to http;//88.blablabla.VirtualDJ.mp3. But wherevea i go 2 dat on my browser or windows media player it jus comes up with some error. Please help by giving a guide on how you successfully have broadcasted. Thanks in advance
geposted Fri 13 Jan 06 @ 12:56 am
By the way, there is a shiny button called "search" in each forum section :) Here is an example:
http://www.virtualdj.com/forums/14427/General_Discussion/Broadcast_from_my_own_computer_help__.html?highlight=broadcast
There are 3 things you really need to check:
1/ If you're behind a router, you need to write the external IP not internal which VDj shows.
2/ Make sure VDj has access to internet (no firewall blocking, opend ports, etc.)
3/ If you're using a demo version, the broadcast time is limited (if I read forums correctly).
Ps.: Usually tutorials are available in users' blogs and in posts with higher level, which are only accessible when purchasing a full version.
Regards.
Regards.
geposted Fri 13 Jan 06 @ 9:42 am
Not all information is available to Non License Users. I hope what you find is enough for you.
geposted Fri 13 Jan 06 @ 11:16 am
