Forum: Old versions
Topic: Console/VirtualDJ - question
echorecPRO InfinityMember since 2004
hi
I'm a DJ Console owner - running the Console version of VirtualDJ.
I'm trying to work out what needs to be done to adjust the speed at which the jog wheels control the pitch bend of the virtual vinyl (I find it moves the vinyl too slow if you want to emulate scratching) is this controlled thru the skin .xml file ? or the VirtualDJ settings or is it a firmware issue for Hercules ?
thanks in advance
[echorec]
geposted Tue 11 May 04 @ 4:55 pm
kaleoPRO InfinityMember since 2003
We cannot change this on the xml file, nor on some settings :(
geposted Wed 12 May 04 @ 8:27 am
