Topic: Can you take away...
StyxWGHome userMember since 2006
Say you have a song, can you take away the beat or the lyrics while keeping the other? if so how.
Thanks always
geposted Thu 09 Feb 06 @ 3:10 am
JeremKPRO InfinityModeratorMember since 2004
no this isn't possible, it's like taking the eggs out of a backed cake.
but you can try using some VST effects and try the "vocal +" plugin of vdj that can take a part of lyrics or beat off a song.
geposted Thu 09 Feb 06 @ 4:00 pm
Alright Thank you.
geposted Thu 09 Feb 06 @ 8:39 pm
PionaraPRO InfinityMember since 2004
A simple solution to this (or at least the beat part) might be to use a keyboard shortcut for 'kill bass' i suppose...but it might not be enough.
Try it out and see how you get on with that.
P
geposted Thu 09 Feb 06 @ 8:42 pm
If you belong to a record pool, when they send you new releases on the 'B' side there will typically be the 'instrumentals' of the song and the 'accapella' version.
I hope that is some use to you
geposted Sat 11 Feb 06 @ 8:21 pm
There are plugins available that can do a great job of cutting the vocals or the music. These plugins are only available to full versions members.
geposted Sat 11 Feb 06 @ 11:03 pm
