Forum: Old versions
Topic: Problem setting up multiple cue points using MK2
I am using the virtual dj software provided with the mk2. I have followed all directions for setting up a multiple cue on my mk2. I switch the mk2 from fx or loop to cue mode. I stop the mp3. I press cue and its sets the cue point. My problem comes in when I try to set multiple cue points. I follow the same set up as described before but instead of pressing the cue button I press 2 or 3 like the manual states. This just stops the other turn table (mapping issue?). Ive updated the drivers, reinstalled the virtual dj software, and even rebooted my cpu! Please help.
geposted Fri 17 Feb 06 @ 4:00 pm
This problem is fixed in virtual dj 3.3 professional and dj console edition, what version do you use?
i AM USING THE FOLLOWING:
PACKAGE 1.CMK2.2006
FIRMWARE V1.3.12.6
DRIVER V3.2.0.0
DJ API V1.3.5.0
CPL V1.2.0.8
So strange, I remember this problem on the versionio 3.2 solved in the 3.3.
I'm not sure you can set multiple cues point with the default mapper included in VirtualDJ: i will verify
