Topic: pioneer/vdj
is pioneer's equipment(cdj 1000 and djm 909)compatable with vdj, can you connect the turntables/mixers to your pc like the xp10
geposted Wed 15 Mar 06 @ 9:34 am
JeremKPRO InfinityModeratorMember since 2004
No!
xp10 is a computer based controller. It will be connected to the computer with USB.
CDJ1000 is a CD turntable, you will only be able to connect it to the computer through your soundcard for example to use with TCCDs.
You can connect any soundcard or cd/vinyl turntable to the DJM909, this includes all computer soundcards and xp10.
geposted Wed 15 Mar 06 @ 11:53 am
ok thanks for the info
geposted Wed 15 Mar 06 @ 8:33 pm
