There are a lot of tweaks that I like in this software... Shortcuts are my favourite, the effects shortcuts are tricky, each key holds a different value... The trick is to set each for a task.. eg:-Three effects means three keys, I use Q,W,E, now to set the values Q is effect one ..the value for Q will be one,W is effect two, the value is two etc...Each key HOLDS a different value.. Shortcuts are very handy u can play Vdj without useing a mouse...You can also reassign a shortcut of your choice...The difference between ATOMIX & VIRTUAL dj is that atomix can auto loop while you need to assign a shortcut for virtual dj..To do that in the shortcut menu look for [go to cue] setting, assign a key letter of your choice & your ready....One more, to set a cue look for [set cue] setting, assign a key letter as before...That's all ...
geposted Sat 18 Mar 06 @ 12:04 pm
HELLO
geposted Fri 30 Jul 10 @ 11:43 am
