Forum: Old versions
Topic: DJCMapper and Mixed Mode... cant change audio source
ReTangoPRO InfinityMember since 2006
Hi, Im using VDJ with DJC MK2 and DJCMapper. I just selected mixed mode for MK2 to be able to play an external source, but when i press the "Audio Source" button i cannot listen to the external source (the green light turns on and off, but nothing else happens). If I remove DJCMapper it works ok, so I figure its something I´m making wring with the plugin. What "action" and parameters should I select for the "Audio Source" button in DJCMapper? Currently I have "select" and 0 as a parameter, Absolute Value
Thanks a lot,
ReTango
geposted Sun 02 Apr 06 @ 5:25 am
ciocePRO InfinityMember since 2004
geposted Sun 02 Apr 06 @ 11:43 am
