Topic: Is this possible ???
I was informed about a feature where VDJ adjusts the pitch (sync) automatically to match the the other decks BPM instead of the user hitting the "AUTOBEAT" button when each a song is loaded...ohh by the way I'm refering to VDJ in conjunction with the Hercules MK2.
Is there an option in the Config Menu that needs to be activated for this feature???
geposted Tue 11 Apr 06 @ 6:51 pm
Config > FAME Settings > Auto BPM > Enabled
geposted Tue 11 Apr 06 @ 6:56 pm
Perfect..THNX a LOT!!!
geposted Tue 11 Apr 06 @ 8:04 pm
Also I would love to re-map (assign) the pitch control buttons to the Volume Sliders and vice versa, Can this be done ???
geposted Tue 11 Apr 06 @ 8:07 pm
xeonPRO InfinityModeratorMember since 2004
Yes, in preferences of VDJ where you enable DJConsole.
geposted Tue 11 Apr 06 @ 8:15 pm
Can someone PLZ give better instructions for re-mapping keys with my Hercules MK2...THNX!!!
geposted Thu 13 Apr 06 @ 6:42 am
TotyoHome userMember since 2006
You can map your buttons with djcel's djc mapper (download > plugins > soundeffects). to download you have to buy pro
geposted Thu 13 Apr 06 @ 9:24 am
but if you just want to invert pitch and volume controls > config > remote control > tick in/out invert pitch/volume square
geposted Thu 13 Apr 06 @ 9:27 am
I cant thank you enough for the advice thus far...Really appreciate it.
geposted Tue 18 Apr 06 @ 8:56 pm
