Forum: Old versions
Topic: Scratching sounds bad!!!
clore46PRO InfinityMember since 2006
I have tryed the TCCD's and the scratching sounds horrible. At first i thought it was my Denon 6000's but i have since moved to Pioneer CDJ-800's and it is still very poor. Is there a setting adjustment to fix this problem? Ive only been using my factory installed soundcard w/ the ASIO driver to test TCCD out. I dont want to invest in a soundcard if i am going to have the same problems. Any help would be appreciated, thank you.
geposted Thu 13 Apr 06 @ 3:34 pm
well with 3.4 the scratch sound is much cleaner then it was in previous versions. if your scratch sound is aweful might be latency wise which would result in having a non ASIO soundcard. I can definatelly say that version 4.0 has a whole new sound engine wich it really great with scratching so if you don't get what your expecting now wait till 4.0. Its pretty much like a real vinyl.
Best Regards
DJ White Devil
geposted Thu 13 Apr 06 @ 4:59 pm
Does anyone know if 4.0 will be available as an upgrade or will i have to buy the numark version?
geposted Thu 13 Apr 06 @ 5:33 pm
listen2PRO InfinityMember since 2005
i think the answer of now is that its an update.
geposted Thu 13 Apr 06 @ 6:14 pm
Thnaks for the help. Anyone know when the update is expected to be available?
geposted Thu 13 Apr 06 @ 7:41 pm
apopsisdjPRO InfinitySenior staffMember since 2003
Only God knows, believe me...
geposted Fri 14 Apr 06 @ 4:26 am
it will be an upgrade more then likely.
Virtual DJ is Virtual DJ.
Virtual Vinyl is Virtual Vinyl.
I'm sure Atomix will want to keep it like that ;).
Best Regards
DJ White Devil
geposted Fri 14 Apr 06 @ 4:17 pm
Will there be new timecode vinyl with 4.0? If not a answer mabe a hint! LOL
geposted Thu 06 Jul 06 @ 5:54 am
djsherzPRO InfinityMember since 2006
Now now, this isn't turning into another "when's v4 coming out" thread is it people?? ;-)
geposted Thu 06 Jul 06 @ 9:25 am
Actually since i went to a maya44 usb, it sounds much, much better. I use VDJ 3.4 at all of my gigs now with TCCD's!!!
geposted Thu 06 Jul 06 @ 4:27 pm
i suspected it would be a soundcard issue, as i've tested it out on my dz1200, numark somethings (some cheapish dual cd deck) and a pioneer cdj 800 and not had any problems with it.
geposted Thu 06 Jul 06 @ 5:23 pm
