Try as I may, I can't find a way to reset the default (opening) values of my volume sliders to anything other than the original settings (100%).
Anyone have any tips to offer in this regard? I can't seem to find the appropriate attribute. I want them to open at 75%, but zero would be better than the way they are now...
geposted Mon 24 Apr 06 @ 3:41 am
The only way I found to do this is a KEYBOARD SHORTCUT.
Use same key for both players and config this way:
FUNCTION > LEVEL > VALUE = 3072 (so, 75%) > on deck 1
(same key for:)
FUNCTION > LEVEL > VALUE = 3072 (so, 75%) > on deck 2
Press the KEY each time you open VDJ.
(same key for:)
geposted Mon 24 Apr 06 @ 9:29 am
Right,.. that's what I'm doing now, except I do it with the mouse (dblclick=2840).
Thanks for your input, but this appears to be an oversight by the developers, and needs to be addessed.
Perhaps a new perimeter such as "defaultvalue=".
geposted Mon 24 Apr 06 @ 1:45 pm
Yes, could be great to have a "defaultvalue" of some item so when we open VDJ we'll find it just like we want. :)
geposted Mon 24 Apr 06 @ 4:53 pm
