BPM detection is great feature, but time to time i must play any "for mixing unusable song" (any rock songs, any "folklore" at wedding or birthday party etc.. :-) and when i drag this song in the deck, there is usually bad BPM detection and beat grids.
When i sort whole database by BPM, I have this song with false BPM information betwen other good detect songs and it is annoying. Yes, i can change BPM to 50 or 200 BPM, but better choice is completely disable BPM information and beat grids for this song.
I found that where i remove from virtualDJ database.xml BPM tag , BPM and beat grids are no more show in the database or in the waveform.
May i delete this BPM tag without risc of any crash or freezing VDJ ?
I hear that you are working on the new database engine. Can you add this (small) new feature - right click at the song in the database and select from drop down menu "disable BPM" for deleting BPM tag from database?
Thanks
Thanks
geposted Tue 25 Apr 06 @ 2:49 pm
you can delete the bpm values about edit_bpm button and delete the bpm or change it manuall without analize.*g*
geposted Tue 25 Apr 06 @ 5:50 pm
No, manual delete BPM in "adjust BPM values" always set BPM to 200. Tested in VDJ 3.4. I want completely disable BPM for a few my songs, because any of my song are unusable for mixing. For example: Beatles - Yesterday - there is 7/8 tempo and beat grids are only illusory.
geposted Tue 25 Apr 06 @ 7:08 pm
actualy i think its 4/4 in yesterday, good try tho
geposted Wed 26 Apr 06 @ 12:59 am
I have read about this long time ago - there are seven beats in each bar. But i'm not sure. You can try count beats in next interesting song - "Pink Floyd - Money". Maybe this is a better example :-)
geposted Wed 26 Apr 06 @ 1:36 am
