Fruit, like i said in other thread, thanks for the tip on getting 1.08 default advanced skin into 1.09. I'd like to be able to add the the 1/4, 1/2, & 16 second loop buttons into my new 1.08 skin/1.09 engine combo if it's at all possible. This is not a request for you to do it, i know skinning takes a lot of time. Question is: since it's just adding those few and changing nothing else, is it something I'd be able to do myself without any skinning, xml knowledge? Like a short explanation u could give me or point me to without having to learn skinning from the floor up. Like just saying, ok, go here, insert the words and numbers blah blah blah this for that for that under so and so folder and presto! If it's too lengthy a process I'll just forget about it.
I do like the skins you guys have put together on the side, i just like simplicty of vdjs default skin and for better or worse, comforable with it.
thanks!
thanks!
geposted Mon 07 Jun 04 @ 1:07 am
Wow it's a bit hard to explain but add me to msn we'll see that.
For the moment, the few time I have is for the dcd pro 1000, it's a hard skin :-( I have to work harder.
Maybe after that...
FRUiT94
Maybe after that...
FRUiT94
geposted Mon 07 Jun 04 @ 1:24 am
no, no fruit, i wasn't asking u to do it, I swear. i know you're busy. I was just being naive thinking I could somehow do it myself with little hassle and no skinning smarts. But i was jus being lame. for my tastes, I really mostly use and need the 2, 4, second loop already there. sometimes i use the included 8. I just wanted the 1/4, 1/2, 16 sec. as a luxury option but since I wouldn't use it all the time like the others, it wouldn't make sense to put tons of time into adding. thanks again though fruit, you're coolio.
geposted Mon 07 Jun 04 @ 1:54 am
Add me to your msn I will try to explain...
geposted Mon 07 Jun 04 @ 7:11 am
ok
geposted Mon 07 Jun 04 @ 8:21 am
