Forum: Old versions
Topic: RECORDING with TCV's
can sombody walk me through step by step on How to configure my VDJ software or computer to record my TCVs...Everything is working fine, but, when I record I get a blank audio file. I can't hear anything. what could cause this, i set the VDJ recording to Line in...i'm using a MAYA44 usb soundcard.
geposted Thu 27 Apr 06 @ 1:16 am
Slash4PRO InfinityMember since 2003
You have to plug you mixer-out to the line-in of another soundcard for recording (you have an embedded soundcard with you motherboard I think, just select this line-in for recording).
Check in windows that this line-in isn't muted for recording :-)
Slash
geposted Thu 27 Apr 06 @ 10:11 am
okay, well now how i am i supposed to hear the music, out of my speakers??
geposted Fri 05 May 06 @ 9:06 pm
listen2PRO InfinityMember since 2005
your mixer should have 2 outs, rec & booth/main. rec is going to your soundcards line. main/booth is going to your speakers/stero/amp whatever you normally listen with. I'm guessing you have another card on your motherboard.
geposted Fri 05 May 06 @ 9:52 pm
well yes i have a laptop w/ a souncard is that on my mother board??
geposted Sat 06 May 06 @ 1:38 am
