Forum: Old versions
Topic: ? on xp10
if you move the pitch slider on the xp10 does vdjs pitch slider move along with it, if yes then if you move the pitch slider on the xp10 to -15% and load a track on it does it automaticly play at -15% and does it stay at -15% if you load another track on the same xp10
sorry 4 all the ?'s
geposted Thu 27 Apr 06 @ 6:27 am
Slash4PRO InfinityMember since 2003
No, the pitch will reset in VDJ, so youre XP10 pitch will be 'out of sync'.
But you can easily resync it using the option button 1, allowing you to move the XP10 slider without affecting the VDJ one.
geposted Thu 27 Apr 06 @ 10:05 am
xeonPRO InfinityModeratorMember since 2004
what do you mean with "option button 1"?? :) i was doing it in different way :)
geposted Thu 27 Apr 06 @ 11:44 am
Give it a test : move the slider while holding switch 1 (top left button) and two (his neighbor) ^^
geposted Thu 27 Apr 06 @ 11:48 am
wow :D i just like this software! :D
geposted Thu 27 Apr 06 @ 5:25 pm
You can test them with all buttons, sliders and even Wheel ^^ You'll have suprises.
The wheel with opt1 and 2 is funny with loops... test it ^^
geposted Thu 27 Apr 06 @ 7:36 pm
when you resync it with option 1 its possible with the eks version
geposted Fri 28 Apr 06 @ 4:53 am
Of course... VDJ and EKS XP10 are the same (at least under VDJ)
geposted Fri 28 Apr 06 @ 9:09 am
