Forum: Old versions
Topic: hercules MK1 and two xp10's
jaakkoPRO InfinityMember since 2006
Here is some basic noobie questions which may have been asked before....(sorry)
I have old hercules dj console (version mk1). I'm interested in buying two xp10's. Can i plug to xp10's to the hercules console to get em work? Or do i need an external mixer?
If yes, what is a good and cheap (less than 100 euros) mixer to work with xp10's?
geposted Thu 27 Apr 06 @ 10:17 pm
ciocePRO InfinityMember since 2004
geposted Thu 27 Apr 06 @ 10:57 pm
xp10s are usb devices..
they are not plugged to an external mixer, but directly to your pc;)
and yes, you have have both hercules + 2x xp10 connected, if you have enough usb ports :)
The sound out from the xp10 is a different case.
The best thing would for sure to connect the audio out to an external mixer ;)
geposted Thu 27 Apr 06 @ 11:02 pm
So all three controllers are usb-plugged only? No connection between hercules and xp10s? Then I can control decks with xp10s and use hercules as a mixer (crossfader, eqs)?
Which controller i will connect to amp (I don't have mixer at home, amp only). Now I have console only, connected to amp and works ok. Xp10 would be a better soundcard than hercules though, right?
geposted Fri 28 Apr 06 @ 9:18 am
