Forum: Old versions
Topic: Problems with music files.
WoozieHome userMember since 2006
Hello guys. I recently got the VirtualDJ 3.0 with hopes to mix some songs I got in iTunes. When I went to scan my PC, it didn't find my iTunes songs??? I went to the extensions toolbar and added the type of file they are. (M4P running with Windows Media Player, or, MPEG4 under iTunes {eaither way I added both file types}) It comes up as corrupt or somthing but gives me an error when I try to play/mix them? I'd love to get mixing so thanks in advance for the help.
Mike
geposted Sat 29 Apr 06 @ 11:58 am
phillydjPRO InfinityModeratorMember since 2004
I believe you have to open the Itunes extension with the quicktime audio codec BUT .m4p is DRM license protected so i really doubt your gonna be able to play it. Recently VDJ started support for windows media drm protection but not itunes protected files sorry maybe in the next update on that same note any m4a's you have should be just fine the should be set to open with your quicktime audio decoder by default
geposted Mon 01 May 06 @ 2:15 am
geposted Sun 18 Jun 06 @ 12:30 pm
