I'm having driver compatibility issues with my Ecler Nuo 4 -- this has now affected VDJ in that now when I start up VDJ it says "the internal database is corrupted"... And all my analysis of files, and comments (which were quite extensive) are gone. Anyone know if there's a way to recover these? Any way to fix the corrupted database? Thanks in advance for any help!
geposted Sat 29 Apr 06 @ 10:25 pm
sorry bud, but you'll need to re scan everything... it's gone!
next time, back up your virtual dj database xml and keep it in a safe place...
I learned the hard way too!
set aside a few days for scanning!
geposted Sun 30 Apr 06 @ 2:56 am
actually there is a way to correct any database corrupted. Very often it's only a little error.
Open your file with pad or word and edit it.
Look how the information are listed and respect the general syntax.
It is a long and boring work I know :s
Good luck
Good luck
geposted Sun 30 Apr 06 @ 10:33 am
In general it's the first line in the xml which isn't at the end with / before
geposted Sun 30 Apr 06 @ 12:29 pm
Thanks guys! Figured out how to fix it...
geposted Sun 30 Apr 06 @ 9:07 pm
you bastards! When I had this problem everyone told me to just re-scan..... :)
so now you tell us!
Great info, and I stand corrected sir...
sorry!
so now you tell us!
sorry!
geposted Mon 01 May 06 @ 5:38 am
@Steve Lynch
Maybe you have a different problem then, not at the beginning of database? Is database always corrupted at the beginning? I use 3 backups (after every night I play), so if one goes, there's always 3 for me ;) !
geposted Mon 01 May 06 @ 4:00 pm
sure it is strongly recommended to save your current database in a safety place (not at the bank lol).
As far as I am concerned I have three several version of my database in my VDJ root folder
VirtualDJ Database.xml
VirtualDJ Database.xml.bis
VirtualDJ Database.xml.bis.bis
Every week I delete VirtualDJ Database.xml.bis.bis and I rename VirtualDJ Database.xml.bis into *.bis.bis
and I rename VirtualDJ Database.xml into VirtualDJ Database.xml.bis
I keep a copy of the last file as the proper VirtualDJ Database.xml
And the three files are saved in another place (a partition devoted to the backup).
This file is as important as that your music :)
geposted Mon 01 May 06 @ 8:42 pm
What kind of information do you all put in the comments field? Just curious... I used to have very specific information about what happens at different timepoints, but became too much to read when choosing tracks on the fly... Nowadays I tend to only put very simple statements about the overall tone/mood of the track. What do you all put in the comments ?
geposted Mon 01 May 06 @ 9:35 pm
