Forum: Old versions
Topic: Help!! TCV Techniques Mk2
techno1PRO InfinityMember since 2006
I cant get both of my Techniques to work with Virtual
DJ 3.4 at the same time, this is what I have:
1. 2 Techniques mk12s
2. 2 Virtual DJ Timecoded Vinyls
3. Maya44 Usb Audio Card
4. Laptop (Dell *Brand New*)
5. Mixer and DJ Speakers (*Mixer Has 3 Channels*)
6. The How to Adobe Instructional on How to set up the Timecode Vinyls with Maya44 usb.
7. Registered Version of Virtual DJ 3.4
8. Creative SB Live! 24b External USB Sound card
9. asio4all software
but when i use asio4all, it says not that many
channels, and cant get them to work at all.
without asio4all, i use maya44usb and it works with one
turntable only 100%, the 2nd does work a little with 0%, but only for 5
mins then it doesnt scratch, and one side detects tvc
and the other side doesnt.
Help!!!
geposted Mon 08 May 06 @ 7:51 pm
listen2PRO InfinityMember since 2005
Check to see the options if you have the channels assigned correctly, EX. 1-2 left 3-4 right, you should see something like are they both grounded to the pc?.
look at these blogs
http://www.virtualdj.com/blog/Dams/blog738.html (only use the Y adapters if your planning to use real vinyls too)
http://www.virtualdj.com/blog/coronaextra/blog1335.html (this blog is for tccd's but is the same setup almost(minus the vdj vinyl settings and a ground needed) and this one has pics for the maya44 settings)
geposted Mon 08 May 06 @ 11:02 pm
