Forum: Old versions
Topic: 2x XP10 Controller use over a USB Hub???
JayDeePRO InfinityMember since 2003
Hi Froum,
is ist possible to use 2 XP10 Controller with 1 USB Hub?
My PC has only 2 USB ports but one port is still reserved fo the Bluetooth USB Desktop.
Thanks for your feedback
JayDee
geposted Wed 10 May 06 @ 4:23 pm
Slash4PRO InfinityMember since 2003
I use them with a USB Hub without problems. BUT adopt a powered USB Hub if you want to be sure it will not mess up your config....
XP10 like very stable DC power..
geposted Wed 10 May 06 @ 4:37 pm
Buy a 2.0 USB adapter...they are cheap cost under 15 bucks!!!
geposted Fri 12 May 06 @ 5:05 pm
acw_djPRO InfinitySenior staffMember since 2005
and be sure it is a poowered USB 2.0 HUB, as slash saids, it's better.
geposted Fri 19 May 06 @ 8:25 am
