Topic: computer $200
hey,
I went to this computer junkyard place and I found a pentuim 4, 512mb, 40 gb hard drive pc for $200. It comes with everything and a sound blaster sound card. Do you think this is a good deal? thanks
geposted Sun 14 May 06 @ 2:28 am
DJ-ALFPRO InfinityModeratorMember since 2005
For that price it is ok, but check that is not bad quality or malfunctioning somehow. Cheap things sometimes have hidden faults that seller will never tell you!
geposted Sun 14 May 06 @ 2:44 am
sbangsPRO InfinityMember since 2004
check if they offer any sort of promise that it will work
geposted Sun 14 May 06 @ 11:37 am
Ok I will make shure. Thanks for the advise.
geposted Sun 14 May 06 @ 6:20 pm
d rocksPRO InfinityMember since 2006
If it is plugged in and connectedm maybe take a copy of this software install TEMPORARILY and connect your external hd. If they want to sell bad enough, shouldn't be an issue
geposted Mon 15 May 06 @ 2:57 am
