Forum: Old versions
Topic: Asio and virtual dj 2.0
When I use the asio. Virtual dj say's error in the ASIO sounddriver.
soundcard waveterminal 192L
driver version 4.3
asio version 2.0
In all the other sound prgs in works fine.
geposted Fri 11 Jun 04 @ 9:03 pm
DJ CyderPRO InfinityModeratorMember since 2003
Same here asio DOES NOT work with the waveterminal 192L with version 2.0 vdj
I've tried everything :( asio has no problems in other programs with the WT192.
I just get this box saying there is an error in asio and the sound quits. In wdm mode it works fine.
geposted Sat 12 Jun 04 @ 4:02 pm
Morris
I did get it to work with the drivers you suggested but it was so buggy I deemed it unusable in a gig situation also the drivers suggested sounded worse than the WDM drivers.
I guess I'll wait till its worked out to use asio with the WT192
thanks anyway tho :)
geposted Tue 15 Jun 04 @ 7:14 am
I was VERY pleased to hear 2.0 supports ASIO.
So i put my Hercules console in ASIO-mode, i also get an error and vdj exits. runs just fine in DJ-mode.
what's wrong?
geposted Tue 15 Jun 04 @ 10:11 am
I'm sure it will be fixed in 2.01 :)
geposted Tue 15 Jun 04 @ 9:33 pm
wyworgPRO InfinityMember since 2003
version 2.01??? or 2.1??
geposted Tue 15 Jun 04 @ 9:39 pm
I thought .0X versions were bug fixes and whole nember were major changes even new features? I could be wrong.
geposted Tue 15 Jun 04 @ 9:43 pm
why not 2.0b??? ;)
geposted Wed 16 Jun 04 @ 12:13 pm
djzeroPRO InfinityMember since 2003
its only a number (or a letter) guys an update is a update, just cant wait till hte next one they just keep getting better
geposted Wed 16 Jun 04 @ 12:28 pm
