Forum: Old versions
Topic: duplicates! [solved]
hi,i'm using vdj 3.4 seems somehow i have two of every song in my database,i think it probably happen when i accidentally import files from my external backup drive..is there a quick way to delete all the extra song files.i spend a lot of time manual doing the bpm on a lot of songs,don't want to do that again!!i'll be happy for any help thks..
geposted Tue 16 May 06 @ 1:53 am
JeremKPRO InfinityModeratorMember since 2004
I think the solution would be to rightclick on your Local Database and then delete a hardrive. No worry it won't physically delete songs but only remove them from the database.
geposted Tue 16 May 06 @ 1:22 pm
thks jeremk that works perfectly!!!
geposted Tue 16 May 06 @ 2:43 pm
Great :)
geposted Tue 16 May 06 @ 4:33 pm
