Forum: Old versions
Topic: Flanger effect?
stylusHome userMember since 2006
Hi vdj fans, i used to use the original atomix mp3 program where the flanger effect could be activated by just clicking on the effect. But how do you use the flanger in vdj? I see the beat grid on the right side of my screen, and then on the left it has about 8 different effects, i think the flanger is fourth in line, so do you just click on that effect, it doesnt seem to activate. Thanks for replies.
geposted Thu 18 May 06 @ 12:17 pm
sbangsPRO InfinityMember since 2004
On the Effects/remix tab of the program look for Effects Press 1 to activate effect 1 , 2 for 2 and so on
to assign effects drag and drop the effect , into a slot
on the effects page
geposted Thu 18 May 06 @ 12:43 pm
Thanks for the help :) One other thing concerning effects, is it possible to download different effects using some kind of plugin? I would love an echo effect, i assume vdj doesn't have this effect at the moment?
geposted Thu 18 May 06 @ 7:40 pm
JeremKPRO InfinityModeratorMember since 2004
geposted Thu 18 May 06 @ 7:48 pm
erxonPRO InfinityMember since 2003
There is more than one echo effect for VDj. (effect = plug-in) You can download any effect which has home edition status here:
http://www.virtualdj.com/addons/view.html?type=sound%20effect&page=1
Two examples of echo, both only for professional edition users:
ECHO V2.01
- by kaleo -
- Professional edition user level only -
Author: kaleo - Ultra-VIP Member -
Description:
For VirtualDJ 2.XX (some bugs fixed) This plug-in add echo to the song. The echo delay can be adjusted to the beat. You can also mute the song and listen the echo going away...
http://www.virtualdj.com/addons/download.html?addon_id=69
EchoOut
- by macourteau -
Author: macourteau - Support team -
Description:
digijoc-mele's idea. This is the same as LoopOut, except that the music keeps playing, which creates a sort of beat-aware echo.
http://www.virtualdj.com/addons/download.html?addon_id=661
Regards.
geposted Thu 18 May 06 @ 7:49 pm
