Whne using Virtual Dj on my gigs at least once a night it will just close completely going back to the windows desktop, then for the rest of the night seems fine, please help as this happens quite a lot I have eben re-installed my computer and vdj and still it does the same thing, this never happened in earlier versions
geposted Fri 19 May 06 @ 1:11 am
so try to install previous version.
Theoretically the problem could be that it was working in the past, but now your RAM can be corrupted or something that causes VDJ to crash.
Also try to install the same driver versions you previously used when all was working.
geposted Fri 19 May 06 @ 11:16 am
Do you use VirtualDJ v3.4 or a previous version?
geposted Wed 24 May 06 @ 9:15 pm
If it still happens after trying a previous version, do a memory test.
Windows Diagnostic Memory (http://oca.microsoft.com/en/windiag.asp)
Memtest86 (http://www.memtest86.com/)
Memtest+ (http://www.memtest.org/)
I've been using Windows Diagnostic Memory and always detected errors properly, but I've seen several computers where it doesn't boot at all, if so, give a try to Memtest+
geposted Fri 26 May 06 @ 4:06 am
