How do I configure VDJ for my dj system? How do I listen to one side while the other side is playing? My dj system consist of a 2 chanel mixer, 2600 power amp and my speakers.
geposted Thu 08 Jun 06 @ 8:23 pm
Get a Hercules DJ Console.
geposted Thu 08 Jun 06 @ 8:24 pm
theres no headphone or advanced sound configiration in the demo version
geposted Thu 08 Jun 06 @ 8:33 pm
i have dj controle mp3 standerd virsion can i use pro virsion with it
geposted Fri 09 Jun 06 @ 3:41 pm
Yes, of course you can ;-) But you should insert your serial in your profile if you want VDJ at a discount price : http://www.virtualdj.com/purchase/discount.html
geposted Fri 09 Jun 06 @ 3:46 pm
THERE IS A MUCH EAISER WAY TO DO IT MAN.
all you have to get a usb sound card you can get it on ebay and plug it in to the computer
1 select the option inteh sound card tab that showa speaker and a headphone
2. use 2 min to rca jackes one from you onboard sound card and the other from your usb sound card to two different channels in your mixer
3 malke sure that the crossfader in vdj is always in teh middle and teryou go you can listen toone side whle the other plays
geposted Sat 10 Jun 06 @ 11:42 pm
Good idea from SQUEEZEEYE, but remember that you will need the full version to select this setup within VDJ.
Ewout
Ewout
geposted Sun 11 Jun 06 @ 2:39 pm
