How can I get shoutcast to work with Virtual DJ so I can mix music live as an internet dj?
geposted Sun 11 Jun 06 @ 9:07 pm
VDJ has built in this function. But not trial version. You have to get FULL version of VDJ to do that.
geposted Sun 11 Jun 06 @ 10:05 pm
if the full version how would u set that up? Was checking it out on my buddies computer......couldn't find it....
geposted Mon 12 Jun 06 @ 3:25 am
Let your friend ask this question ;)
It is possible and it works great, believe me. You can search the forum for answers, but until you buy it i can't give you answer.
geposted Mon 12 Jun 06 @ 10:20 am
hi i have full version of vdj still cant get it to broadcast to shoutcast server plz plz help me
geposted Tue 15 Aug 06 @ 3:47 pm
if you have a legal version, enter your serial here:
http://www.virtualdj.com/fusers/modifuser.html
If you are using a bad version, dont expect everything to work.
Cracked versions are often a cracked version of the demo version (remove expire), and many features are disabled in the demo, so also the cracked one. And all cracked version have changed code making them work bad.. on some features.
Legal version have easy built-in support for Shoutcast. Enter IP and passwords, and u are ready to go;)
geposted Tue 15 Aug 06 @ 5:22 pm
Hi im a registered user of DJ MIX STATION 3 Virtual DJ Home EDITION.
and i cant get the broadcast to work?
geposted Wed 16 Aug 06 @ 2:45 pm
