Forum: Old versions
Topic: music library on second screen/monitor
sverreHome userMember since 2006
I have two monitors and I would like to have the mixing part of the prog. (the upper half, standard skin) on one monitor, on the other I want to have my musiclibrary, fx, etc. to choose from. Is it possible and how do I do it?
A quick search gave no answers.
geposted Mon 12 Jun 06 @ 2:35 am
frd1963PRO InfinityMember since 2004
You will need to make a custom skin for this. Check the skins forum. Someone had been looking into this about 4 or 5 months ago. (S)He may have a made a custom skin that you can try.
geposted Mon 12 Jun 06 @ 4:52 pm
It should be possible, but the skin will have to be big enough to span both monitors.. something like 2560 x 1024, and the parts in the correct place.
I'd also assume that fullscreen mode wouldn't work, but thats something to be looked into...
geposted Fri 16 Jun 06 @ 10:13 pm
