Forum: Old versions
Topic: shortcut sample_volume_... problem
how can i make the shortcut example sample_volume_1 thats move the slider.
i can move the position of the browser slider up and down about the skin slider(bitmap ofcourse) but the slider clipmask on skin its not working (moving).and when is working move the bitmap on skin the browser slider is only a bit up and go fast down and the slider bitmap is not showing on skin.and with bitmap button on skin is only up or down with the specific value example +1024 and don`t go higher.
for me it is a little bitmap bug. or gives a any solution yet?
Thanks
geposted Mon 12 Jun 06 @ 8:19 pm
ciocePRO InfinityMember since 2004
The team know the bug and this will be solved in version 4.0
geposted Mon 12 Jun 06 @ 11:36 pm
xeonPRO InfinityModeratorMember since 2004
Just wait till version 4 ;)
geposted Mon 12 Jun 06 @ 11:45 pm
okay thanks.
geposted Tue 13 Jun 06 @ 2:50 pm
