Forum: Old versions
Topic: one turntable/cd player usage
is it possible to use only one turntable or cd playre to control both decks, and how?
geposted Tue 13 Jun 06 @ 4:56 pm
xeonPRO InfinityModeratorMember since 2004
yes, it is. but i don't know if it is possible to use booth with trial version.
geposted Tue 13 Jun 06 @ 5:03 pm
Is very easy you have to select vynil in one deck and cd in the other deck they are independent, disable riaa amp in cd , but as xeon mentioned only in full version is possible, in demo only one deck is available, best regards.
geposted Tue 13 Jun 06 @ 6:01 pm
