Forum: Old versions
Topic: Eval v3.4 - Pitch Adjustments automatically changing
Ok.. so I figured out the automix feature and turned it off thanks to the forum's help.... My question now is... How do you prevent the pitch from changing when you load a song into the other deck? I want to keep the pitch change at 0 at all times unless 'I" change it. I'm sure again its a simple questions. Looked in the keyboard short cuts, but couldnt see where the option was. Found where I can reset it back to ZERO after its changed by the keyboard, but not how to stop it from changing to begin with.
Any help is appreciated.
geposted Wed 21 Jun 06 @ 11:26 pm
Hi, I'm sure this is explained in the userguide but it is easy to adjust without the pictures. Click on the configuration button (the orange cog) and select FAME Settings from the new window which pops up. Disable Auto BPM.
geposted Wed 21 Jun 06 @ 11:31 pm
