Track has BPM set correctly, cue points, and comments added. But it's not in a "AUTHOR-TRACK" vdj-compliant naming format... so,
right-click on title > rename > enter vdj-compliant filename
... surprise! BPM/comments/cue-points are completely lost :(
I'd think the point of having this rename function is to feed the old-to-new name change to the song DB so that this doesn't happen.
I'm not sure, but I think this had been fixed from 1.08 to 1.09 (dj console edition), but I might be smoking crack.
I would be very grateful if you could include a fix in a future upgrade.
many thanks,
Nicolas
many thanks,
Nicolas
geposted Thu 17 Jun 04 @ 9:29 pm
