Forum: VirtualDJ Plugins
Topic: Bass / Mid / High LFO
claxPRO InfinityMember since 2004
Great plugin but when when stopped the equalisers don't reset.
Could you fix or may be this is not a bug.
Clax
geposted Fri 18 Jun 04 @ 12:31 pm
I programmed it so you can stop it when you want and it stays at it's current volume... but I could reset it to "0" (in the middle) if users prefer it that way... :)
macourteau
geposted Fri 18 Jun 04 @ 3:45 pm
In my case I prefer but I don't know what the other users want.
Thanks to look at my suggestions.
geposted Fri 18 Jun 04 @ 5:57 pm
I have added an option that, when activated, resets the slider's volume when the plugin is stopped.
It shoud be updated in the addons section as soon as it is 'reviewed'.
macourteau
geposted Fri 18 Jun 04 @ 6:26 pm
The update is now available :)
macourteau
geposted Fri 18 Jun 04 @ 7:13 pm
Hi Macourteau
I had a problem with LFO plugin.
I loaded it into chan 2 and ... the plugin worked on the deck 1.
Strange phenomenon isn't it ?
Maybe a wrong parameter ?
Clax
geposted Mon 21 Jun 04 @ 1:10 pm
I'll check it out as soon as I have time (I'm currently away from home, and all I have to test is a Celeron 600 with 128mb ram lol).
Cheers, macourteau
geposted Tue 22 Jun 04 @ 2:26 pm
Less PC power but a lot of good ideas.
geposted Tue 22 Jun 04 @ 3:49 pm
hehe definitely less PC power, but maybe a few good ideas... But I also need to have the internet on that PC... The one from which I access the internet is a work computer on which I don't have all my dev software (and I can't use that computer for 'personal' stuff (at least, not during work hours)).
macourteau
geposted Tue 22 Jun 04 @ 8:13 pm
Take your time macourteau. I'm with you. I'm testing VDJ and his plugins as often as possible to get the better of its features.
Good work
Clax
geposted Tue 22 Jun 04 @ 8:40 pm
I fixed the bug that made this plugin work only on Deck 1 in VDJ2. It will be updated on the Effects Plugins page as soon as it's reviewed.
macourteau
geposted Fri 25 Jun 04 @ 8:18 pm
OOOOOoooook macourteau.
That's very kind of you.
Clax
geposted Fri 25 Jun 04 @ 9:06 pm
