Forum: Old versions
Topic: vdj randomly freezes.. i dont understand this one...
cerriexPRO InfinityMember since 2004
im usually pretty good with pc's... but,
i can be loading a track, using an effect, mixing 2 songs together or jus playing a song as normal.. and almost evey time at some point the software will jus freeze up..
this however never happens when its on automix mode and im not using vdj its jus doin its own thing..
does anyone know of incompatible software or win xp sp2 settings that could be causing this?
also is it better to set mem usage for background services or programs? i only use vdj and thats it.. maybe a few little games.
many thyanks
geposted Fri 07 Jul 06 @ 4:43 pm
xeonPRO InfinityModeratorMember since 2004
write your computer specs and go through system optimization guide in my blog.
geposted Fri 07 Jul 06 @ 5:01 pm
cheers matie, but where's ur guide??
geposted Fri 07 Jul 06 @ 5:03 pm
In the middle of all my blogs :D OR click to Comunnity > Blogs and then look under Featured blogs. It is there also.
geposted Fri 07 Jul 06 @ 5:13 pm
