Forum: VirtualDJ Skins
Topic: What Options/Settings Can Be Controlled From the Skin?
SupaconPRO InfinityMember since 2005
When you configure the settings in VirtualDJ in the settings dialogue (i.e., where you select skins, audio interfaces, et al) I know that there are some options that can actually be set from the skin (the main interface of the program), like video effects and video transitions. Is there a way to set more of these? If so, they are not in the Skin SDK document...
I'd like to be able to create a button to link the video & audio faders, and I also would like to be able to set some of the FAME settings (like crossfade time) right from the skin. Is it possible to do these things?
I'd love to know if there are actions or controls that can be included in a skin that are undocumented, or that I otherwise don't know about.
geposted Sun 30 Jul 06 @ 11:07 pm
ciocePRO InfinityMember since 2004
To link the video & audio faders use action="video_crossfade" value="Auto" and for other FAME settings I don't know.
geposted Mon 31 Jul 06 @ 8:22 am
Wow, thanks... I was really starting to think that it couldn't be done!
geposted Wed 02 Aug 06 @ 2:59 am
geposted Thu 10 Aug 06 @ 10:03 pm
