Forum: VirtualDJ Skins
Topic: Can you make an Upside Down Waveform Display?
SupaconPRO InfinityMember since 2005
One feature of Virtual DJ that I love is the waveform display that gives you a graphic representation of the audio before and after you hear it. Lots of other DJ software does this now, and one new product by M-Audio, Synchroscience Torq, has an upside down waveform display for one of the tracks.
Although it might seem a little weird, it actually looks really effective... it allows you to have the waveforms overlap and you can still see each one much better than you otherwise would. Since the peaks can just overlap a bit, it's really easy to see when your beats are lined up too.
Is it possible to make a waveform display upside down in a skin? How about in v4?
geposted Tue 08 Aug 06 @ 3:15 am
JeremKPRO InfinityModeratorMember since 2004
This isn't possible in the actual skin engine. You should post this in New features forum.
geposted Tue 08 Aug 06 @ 12:32 pm
Hmm... okay, I'll do that. It'd be nice to see that option in v4.
geposted Tue 08 Aug 06 @ 12:52 pm
phillydjPRO InfinityModeratorMember since 2004
would be a nice new feature
geposted Sun 13 Aug 06 @ 7:44 pm
