Forum: Old versions
Topic: status bar of loaded track question...
Hi All,
You know that status bar that shows the track position usually placed under the time info or whatever on the various skins? I use Cyder's V-Mix 3 skin... so on it would be under the preview monitor per player. Well I have had loaded various MP3's and VDJ will have scanned the song for BPM's and such. Normally the status bar is lighter for quieter parts of the song and darker for the loader parts of the song. kind of gives you a quick overview of the song and when the break-downs are. Very useful. Well I have loaded some that shows it solid dark color like the whole track was load. I know that isn't normal. So is there anyway to reset what it has scanned by error and rescan the correct info for that?
--- I hope someone knows what I am talking about...
geposted Wed 09 Aug 06 @ 8:37 am
DJ CyderPRO InfinityModeratorMember since 2003
Its about to change al, look at my blog for more details.
geposted Wed 09 Aug 06 @ 4:05 pm
