When I use the version of VDJ that came with mij Hercules DJ Control MP3, it works fine.. but when I use it with the pro version of VDJ, it says that the DJ Control is not connected.....It also says: "you may need to change your DJ Console to "DJ Mode" in the console's config panel if it's not already done". I want to use my internal sound card for my master sound and my external USB Sound card as a monitor... Then I want to use my DJ Control MP3 for al the other functions.... I thought it might work when I set up my sound card like: 2 sound cards, 1 for monitor, 1 for master.....1st sound card = internal, 2nd = usb... Then remote control --> Hercules DJC --> Enable.... but then, it gives a red sign on the right, not a green one...
what to do?
Sjoerd
what to do?
Sjoerd
geposted Tue 15 Aug 06 @ 5:17 pm
wow.... sounds like an old cracked version...
The console does not have dj mode anymore.
It works straight out of the box in the full legal version, so buy the discount upgrade rather than trying to make things work in bad versions.
If you do have the legal version, enter serial here:
http://www.virtualdj.com/fusers/modifuser.html
and get the free upgrade to the latest version of VDJ ;)
geposted Tue 15 Aug 06 @ 5:26 pm
geposted Tue 15 Aug 06 @ 5:38 pm
