Topic: Full VDJ Owner!!
Rory05PRO InfinityMember since 2005
I just bought the full software after using the consoe version for ages!!! YAY! Very happy with myself! VDJ is the best software, has to be said!
RoRy
geposted Tue 15 Aug 06 @ 5:36 pm
DJ-ALFPRO InfinityModeratorMember since 2005
Welcome as a full user! Keep spinin'!!
geposted Tue 15 Aug 06 @ 5:50 pm
Having some small problems though! The usal skin I use is called Floop and now when I use it it won't show the BPM on it! It works on all the toher ones but won't work on this one, the one want to use!! It worked before, why won't it work now!! An I also lost all my BPM's off all my songs! Is their anyway of getting them back?
Rory
geposted Tue 15 Aug 06 @ 5:51 pm
We have posting at the same time :)
I don't know about skin, but your BPM's are in VDJ folder in VirtualDJ Database.xml file, you should back it up before installing the Pro version. I hope you did that, if not, try to recover it with some software like GetDataBack.
geposted Tue 15 Aug 06 @ 5:53 pm
i never made a backup! to excited, didnt think!!! NOOOOOOOOO. can u tell m about that databack thing please?
geposted Tue 15 Aug 06 @ 5:58 pm
im doing a system restore an im gonna try an get it from that! I'll let you know how it goes. Thanks for the help dude!
geposted Tue 15 Aug 06 @ 6:03 pm
I did a system restore to get the database file back, made a copy of it, deleted old VDJ, restarted laptop, installed new one, restarted laptop, copied in old database file and it didnt work! Any ideas?
geposted Tue 15 Aug 06 @ 6:29 pm
it works ;)
Just add your folders again, and do a quick scan (right click and choose add to database search)
1-2-3 seconds... and u are back on track ;)
geposted Tue 15 Aug 06 @ 7:36 pm
now im very confused!!! i've tried to get my bpm's back, i'll jus have to scan them all again! any tips for getting the visuals workin guys? i have a thread in the software section if anyone would like to help! cheers!
geposted Tue 15 Aug 06 @ 8:57 pm
DJ CyderPRO InfinityModeratorMember since 2003
no what you do is a quick scan after you put the new database file in (uncheck bpm box)
geposted Tue 15 Aug 06 @ 9:01 pm
Yes, do a quick scan without BPM analyze, it should work.
geposted Tue 15 Aug 06 @ 9:10 pm
